  4. Problem with UC1705 10 in 1 USB C Adapter
  • JK
    Jason K
    3/27/24, 5:54 AM
    I was referring to the "EP program upgrade". Don't I need to connect the hub to my Windows PC with a USB-A to USB-C cable (USB-A at PC, USB-C at hub)?
    I bought it end of 2021 from Amazon.
    3/27/24, 9:41 AM
    @Jason K
    Yes, you do not need to use the USB-A port, you just need to connect this product port c to your laptop, then Adapter hmdi port connected to another monitor, and finally download the installation package on your laptop, directly update.
  • JK
    Jason K
    3/27/24, 10:09 AM
    This is what I have to do for the "AG solution upgrade". Will the "EP program upgrade" work if I connect the hub with USB-C?
    3/28/24, 1:49 AM
    @Jason K Hi,
    You can try it out and finally let us know the result.
  • JK
    Jason K
    4/2/24, 9:33 PM
    The hub still causes the BSOD when I put my PC to sleep. If I disconnect the hub before putting my PC to sleep, all is OK.
    4/3/24, 2:16 AM
    @Jason K
    Ok, I probably know the situation. Please send your order number and our chat screenshot to this email(Support@seloreglobal.com), and we will take the next step for you.
  • 1
  • 2 / 2
  • None of the HDMI ports work on my SEDK1407 with my Asus Zenbook S 14 (UX5406)
    Comix84 10/7/25, 6:47 PM 4
    Latest: Selore Global 10/9/25, 4:26 AM
    9/16/25, 2:08 AM Bolivia 1
