  4. HDMI port on SUEC0305-ES Doesn't work
  • AC
    Alessandro Ciompi
    3/25/23, 7:46 AM
     Hi.
    I have just purchase the abobe mentioned Selore hubs.
    All usb and card read port doest works  but 2 HDMI  where not recognize by the sistem.
    I have brand new HP notebook  Windows 11 , 16 Gby. I5 system.
    Does hubs need specific driver ?
    What is the function of ISP_AUX tools downloaded from Selore Site ?
    7/13/23, 10:34 AM
    Dear @Alessandro Ciompi
    As far as I know, they have certain requirements for the computer for this product. For example, it needs the computer to have a USB-C port that is fully functional or a Thunderbolt 3 or Thunderbolt 4 port, because only with these ports, it can support an external monitor. So I think you may need to look at the specific model of your computer first, and then you can check the official website to see if the USB-C port supports video output. Of course, if you're in a position to do so, you can find another computer that explicitly supports video output, such as a surface with a USB-C port or a MacBook iPad with a USB-C port;
    Also, I've looked at the driver on their website, but that one seems to be model-specific and requires a monitor to be connected to work properly in order to upgrade, and your current non-display shouldn't work with that program.
    From my experience, I would probably recommend that you check to see if the problem is with your computer or the product.
    If it's a product problem, you can contact their after-sales staff, who are professionals and can surely take care of it for you!
    Selore&S-Global Customer Service
  • SEUC 0507 HDMI-2 does not work
    Benjamin Fryman 12/17/25, 6:14 PM 1
    Latest: Selore Global 12/18/25, 6:21 AM
    12/17/25, 6:12 PM United States
