Why does the network cut out after 5-10 minutes of use?
  • When your network cut out, you can check from the below steps:
    1. Test if there is a problem when only connecting the network cable.
    2. Cross-test. Try to connect the docking station to another device that has an ethernet port.
    3. If the device is OK, check if the Type-C port is loose or if the product works flat on the desktop.
    4. Please try again after updating the network drive.
