  4. SEUC0228 - Monitor Screen freeze
    12/25/23, 11:08 AM
    Hello!
    I have a Selore Model SEUC0228, Serial Number 2312. I use it to connect 2 monitors via HDMI cables.
    Every so often, as much as 10-15 times in 8 hours work day, the device stops working. The two monitor screens freeze. The keyboard, also connected via the docker, still works.
    I have to then unplug and replug the USB connection to my macbook, and it starts working. Repeating it so many times a day is harming my productivity and is frustrating.
    Please suggest a resolution.
    Thanks
    1.2k
    12/26/23, 2:59 AM
    Hi @Aj Daga
    Sorry for the inconvenience.
    Regarding your problem, the solution given by the technical department is to uninstall your previous driver software, then re-download and install the driver. The URL for installing the new driver is: https://www.siliconmotion.com/download/3Xf/a/index.html
    If you don't know how to operate, you can contact our after-sales support email (support@seloreglobal.com)
    Looking forward to your reply
    SELORE Support
    1 likes 0 likes
    12/26/23, 11:37 AM
    @Selore Global Thanks you for your quick response. I have uninstalled-reinstalled the new version. Will come back here if the issue persists.
    12/28/23, 1:10 AM
    @Aj Daga Of course, I will always be here.
    There is another way, you can also contact after-sales support, email: support@seloreglobal.com
    1 likes 0 likes
    12/29/23, 9:54 PM
    Uninstall and re-install of the new version solved the problem. Many thanks.
    1 likes 0 likes
    12/31/23, 1:47 AM
    @Aj Daga 💯
    HDMI port doesn't work
