  4. USB-C to dual HDMI adapter not recognized
    7/16/23, 6:31 PM
    I'm running on Windows 11 and my computer has the following port according to manufacturer specs:
    - 1 x DisplayPort 1.4 Type-C over USB 3.2 Gen 2
    I bought your dual HDMI adapter on Amazon (SEUC0703) and plugged it in my USB-C port and I get an error:
    "Display connection might be limited"
    When I go in in my device manager, I see two usb devices named "Unknown USB Device (Port Reset Failed)"
    Is there a fix for that or should I return the adapter?
    1 likes 0 likes
    4
    1.5k
    7/17/23, 7:42 AM
    Hi @Cedric Duquette ,
    We would like to present our deepest apologies for all the inconvenience caused by this adapter.
    1)Whether you have a phone, tablet or other laptop with a type-C port, if it does not support display output, you can use them to test other USB ports function of the USB C Hub, such as whether an external U disk can work. If it do support display output, you can test whether the Hub's HDMI ports function is good.
    2)If you connect other devices with the USB C hub, and test the USB ports or HDMI ports is normal, then need check your laptop. If the USB ports and HDMI ports are not working properly on any device, it may be hub's problem;
    We would appreciate if you could provide a video during you test.Thanks for understanding.
    We have attached the email address, you can contact our after-sales support email (support@seloreglobal.com).
    Have a nice day!
    selore support
  • TH
    Tia Hamilton
    9/24/23, 8:01 PM
    I am having the same problem. I reached out to customer service but have not heard back.
    10/9/23, 6:35 AM
    Hi @Tia Hamilton
    Sorry for the trouble caused to you. Our customer service team usually replies the information within 24 hours. May I know your order number? And what is your contact channel? I'll check the history and solve your questions.
    Have a nice day!
    selore support
    HDMI port doesn't work
