HDMI and Display port doesn't work my pc with motherboard MSI MPG Z490 GAMING PLUS
  • I have a fairly new computer and all the ports on my 13 in 1 dockstation work except the monitor ports.
    On the other hand, everything works fine on my laptop.
    Could you help me.
    Thank you.
  • Hi @Francisco Aragon,
    Based on your question, it's possible that your computer may not support the function you are trying to use. In order to support this feature, your computer's USB-C port needs to be able to support video output functionality. Generally, this can be achieved through a full-featured port, or a Thunderbolt 3 or Thunderbolt 4 port.
    To determine whether your computer is compatible, you can check the user manual or specifications for your computer's brand and model.
    Selore Support
