Display Port has no signal
  • Both my HDMI work for dual screen setup, but when I plug the in the third monitor to the display port it is getting no signal.  If I disconnect all HDMI and only use the display port, I still get no signal.
  • Hi Ed,
    Thanks for taking time to contact us.
    May know whether you use Display to Display cable to connect your monitor with the display port? If no, please try to use a Display to Display cable.
    If yes, to know the more details about the issues you encounter, and better to solve the problem for you, please kindly advise below information to us via support01@seloretech.c o m, thanks a lot.
    Amazon Order No:
    Detailed Laptops model No:
    Monitor model No:
    We will definitely provide your the best solution.Thanks for your understanding and support!
    Selore&S-Global Support Center
