ISPTool - error in upload firmware
  • Good morning,
    I have already purchased this product from you (via amazon)
    https://cdn.shopify.com/s/files/1/0660/6713/6733/files/UC0218F_Manual.pdf?v=1664509290
    I tried to install the drivers with your ISPTool utility, but I got the part number wrong, and now I have a major problem on an HDMI video port
    Could you kindly send me the correct .bin for this product so that I can restore the correct functionality of all three video ports?
    I thank you infinitely for your help
  • Dear Giovanni,
    Thanks for taking time to contact us.
    May I know do you download an install the drivers form the website? Do you have other laptop? If yes, please try to install the drivers with the ISPTool utility on another laptop and see if have the same problems.
    If still have the same issue, please kindly contact us via support01@seloretech.com.
    We will definitely provide your the best solution.Thanks for your understanding and support!
    Selore&S-Global Support Center
