HDMI out does'nt work : SEDK1401
  • Hello,
    I recently bought a SEDK1401. I use it on my macbook pro 2019. Everything works except the video output. I tried to connect my screen to the hdmi ports and the DP port with an adapter but no solution worked.
  • @Maxime Jaconelli Hi,Maybe you can try connecting with another computer model, because there may be a compatibility issue.
