SEDK2403 wifi SSID
  • Hello, I just purchased the SEDK4023.  dock.
    How do I stop it from broadcasting it's own default wifi SSID?
    Even after I connected it to my own wifi, it's still broadcasting it's own default -- which means anyone within range can reconfgure it, even without a password.
    I also want to change the weather display from celsius to faranheit
    Thank you.
  • Check the dock’s network settings to disable its default Wi-Fi SSID and secure access with a password. The Celsius/Fahrenheit option should be under the weather or display settings.
